0-60 times with EZ
Loss of power after 2 hours of driving
Lift pump wiring harness
I made a few 0-60 runs last night for the first time with the EZ. I had some minor problems with traffic and I felt a bit rushed, so I will try again to verify the times, but I knocked out a 10. 54, 10. 74 and 10. 79 I don't know what the norms are but I was in the 12's without the box. I will test again whenever I can get my rear-end to quit dripping #ad
differential that is. See my other post on that ongoing saga.
1999 Dodge Ram 3500 Quad Cab 2wd; 5 spd; 4:10 LSD rear; Mag-Hytec differential cover; US Gear EGT and Boost gauges. Stewart Warner Fuel Pressure Gauge with dual senders, Westach Oil Temp Gauge for differential. Rancho 9000's on order, PowerEdge EZ Box, Amsoil foam air filter and synthetics in the motor and differential. Cummins Power, don't leave home without it
John, that's pretty good rowing. My stock numbers were 0-60 mph 13. 5 seconds. Haven't yet checked it post-BOMBing. What setting are you using on the EZ?
Kurt Voss
********* 1999 2500 24VCTD AUTO 4x4 QC LB Laramie SLT, Luverne stainless steel nerf bars, 3 piece bug deflector, mopar mud flaps, Line-X bedliner, Blue Chip Fuel Management System (Premium), Psychotty Air, DD3's,TTPM, DD 4" exhaust, HX40, DTT VB/TC(91%) , Mag-Hytec transmission pan... YEEEEEHAAAA!!
[This message has been edited by work2muchplay2little (edited 05-10-2001). ]
John's post got me wondering what my numbers were now, so did a few runs with the G-Tech:
BOMB's as listed above, with fueling box off:
0-60 7. 7 seconds average
With fueling box on max (no power braking):
0-60 6. 9 seconds
1/4 mile 15. 8 seconds at 87 mph
With fueling box on max (power braking to build booost):
0-60 6. 4 seconds average #ad
Will have to get this thing on a dyno some day soon!
I got the EZ on setting 3. Tonight I did a couple of more. I got a 10. 77 and an 11. 30. But I think I screwed both of them up. I'm using a reliable stopwatch, but holding the clutch and launching in second plus hitting the watch I think I'm off. The reality is probably somewhere in between. Before the box I was in the mid to high 12's if I remember correctly. I'm going to try to get some more times, but even if the 11. 30 is closer to reality, I'm very pleased with that with just an EZ box. I think I'm cracking 11 though. #ad
The G-Tech is a great little device. If you know someone with one, try it out. They are also not terribly expensive, about $140. Makes this kind of performance measurement way easy, and they correlate pretty well with the drag strip timers and dynos. Check it out http://www.gtechpro.com/prod.html
11. 8 Sec. (stock)
10. 5 Sec. (EZ)
9. 5 Sec. (EZ,DD1,DTT TC & VB)
per hand held stop watch. spent all that money putting this stuff in and and saved myself 2. 3 seconds #ad
yeha I know If I empty the bank I can scweeze another second out of it... . BUT is sure pulls a trailer nice #ad
Kurt what Numbers do you get with a hand held stop watch?
2001. 5 2500 4X4, QC, Auto, 3. 54 LSD, SLT, SWB, Trailer, Camper & Snow plow Packages, White, 35k# Cody Hitch, 20' Gooseneck Lowboy flat-bed Trailer.
1975 Toyota Landcruiser, ARB Air lockers Front & rear, 400 Small Block, SM420 4spd, Stock LC transfer case with 2 or 4 high and 2 or 4 wheel drive Low gears, 15. 5x36" Radial swamper on 12" rims, Custom front & rear bumpers, Roll Cage, Warn 8274 8000# winch, 2. 5" spring lift, 2" body lift. Premier on-board power welder, on-board air, 4-wheel power disk breaks, power steering, Lot of fun.
[This message has been edited by Tom C (edited 05-10-2001). ]
Tom, just used the G-Tech. The clock starts the instant movement is detected by the accelerometer, and the clock stops as soon as you cross 60mph or the quarter mile. I'd say it's likely more reproducible than a stopwatch. It does take some time and care to get it mounted correctly. If anyone is interested, I have the user's manual in a pdf document that I can send you, just email me.
Kurt, How does the device know when you hit 60MPH?
Tom, I've emailed you the manual. Check out page 6 for a pretty good operational theory discussion. Try a search on this site as well. I bought one initially because others had found close corellation between G-Tech results and dyno/dragstrip results. So far, I've really enjoyed it.
I took my truck to the track last weekend and ran 15:53 @ 88. 97mph. Running Super Mental Injectors and a TTPM. I didn't you the Edge Hot box, but I will next time #ad
My truck weighs 6800lbs and it's a 4x4. You should have seen the look on people faces to hear this is a regular thing in the states. #ad
Bomb on guys. #ad
[This message has been edited by Stefan Kondolay (edited 05-11-2001). ]
Stefan, that's pretty impressive, what other BOMBs have you done, and what year/drivetrain is your truck?
My stock 0-60mph went from 16 seconds to
8. 30seconds with the addition of my signature:
Y2K Awesome Black LB 3500 QC SLT, 24Valve ETC ISB, 4x4, 4:10 LSD, DTT Custom prepared Auto transmission VB, Power Edge 'EZ', DD2's, K&N, Polished Stull Billet Grill/Fog inserts, Chrome Smitty-Built Step Rails, Mopar Chrome-Tipped Mud Flaps, A-Pillar mounted West-Tach Turbo/Pyro/Trans Temp gauges, Rancho 9000's, Diamond Plated Tool Box, + a bunch of other stuff. Fact:The First Fords' had 'DODGE' Engines! The new PSD's need them!
Work2muchpay2little:
I have a factory exhaust that has no resonator, and now has a performance muffler. The truck has 3:54 gears. Drilled out the banjo bolts, and relocated the factory fuel pump to beside the tank.
Hopefully it will run 13's with the Edge on.
The fastest that I have run was 14:87 @ 90. 87 MPH. The truck then had 275 injectors, EZ, EDGE. Fuel pump was in the factory location.
Tom C,
The G-Tech determines speed based on acceleration and duration. It also takes into account either no accleration or deceleration during gear shifts. With the same information it calculates the distance traveled.
Not a precise answer but one that may give you an idea of how it 'knows' these things.
<font color=#990000>~<font color=#990000> '99 2500 SLT <font color=#990000> ~ QC ~ 4X4 ~ LB ~ Auto ~ 4:10 LSD ~
<font color=#000000>*<font color=#990000> BD E-brake<font color=#000000>*<font color=#990000> BD Autolock<font color=#00000>*<font color=#990000> Gear Vendor OD<font color=#000000>*<font color=#990000> Bullhide spray-in Line <font color=#000000>*
<font color=#000000>*<font color=#990000> 2k Komfort 5'er - 9,700 lbs <font color=#000000> *<font color=#990000> Jordan Research 2020 T-brake <font color=#000000>*<font color=#990000> Garmin III+ & Laptop software <font color=#000000>*
<font size=-2>... Keep on Rammin'! You'll love the way it feels!! #ad
... <font size=-1>
[This message has been edited by Rattlin (edited 05-12-2001). ]
Update with EZ and 275's
40-60 times
1st run - 4. 86
2nd run - 4. 54
3rd run - 4. 81
0-60 times
1st run - 11. 38 (Operator error!):rolleyes: Loose nut on the gas pedal :eek:
2nd run - 10. 56
Not really sure what happened on that first run. Maybe my muffler bearings or piston covers were out of spec;)
