I have a 2000 6speed. It has the same size flywheel/clutch (12"), and same size input shaft (1-1/4"), as the 5 speed trucks do. Mine does not have the 53 block. The transmission has been reliable and shifts well. The 2001's and after have the larger 13" flywheel/clutch, and 1-3/8 input shaft in the transmission. Southbend has a 13" flywheel/clutch upgrade, so about the only thing you need to be aware of is the shaft may not be as strong. I dont think its a big deal as long as you arent shockloading the drivetrain.
