Hey guys, need a little help with a 2000, 3500,4x4 dually quad cab, about 130,000 miles. I've been fighting with steering lately, and figured I should check the lift pump pressure. I found that it would pressure up to around 12- 14 psi. So while I was under the hood I changed out the lift pump. After instillation, I bleed the system and all seemed well. However, after it sat awhile it became extremely difficult to start. Bleed the inj. pump, (plenty of fuel) but needed to crack the injectors to start it. I ran it for appox. 30 minutes and then shut it off. The truck started right up, but if it sits for 5 min, no start. The inj pump was a new design from O'Reily's. It seemed to build up good pressure but I didn't do a test. The truck seemed like the fuel was bleeding off. Ant ideas? The only good thing about all of this is I now get to use my brother in laws 03 Corvette Z06.
