I have an 01 dodge 6spd manual, has 110000 miles on the meter. We had some cold weather here and one day I went and started it with no issues, let it run for 20 minutes, then shut it off. Went out a few days later to start it after a lot of cranking, finally it starts but runs like it's hitting on 1 or 2 cylinders. So I put a scanner on it and get these codes P0230 P0251,P0252,P0253,PO380,PO382,and P1688. Now, I have since replaced and relocated the lift pump and added a pre pump filter to the frame rail.New ddrp fass lift pump and isspro electronic fuel pressure gauge which tells me I an getting 17lbs at the bottom of the factory fuel filter which feeds the IP. I have done the Blue Chip tests on the IP connector and jumped the 6 and 7 pin as they recommend and it starts but still runs the same as I stated before. So with that being said, what should I try next before I buy a new IP? Just want to be sure I hav'nt missed something in my diagnosis. Any help or ideas would be appreciated. It sounds like it could be the IP but before I pull the trigger on the IP I would like to exhaust all the options. Also bled the injectors that I could get to easily. Also have dead peddle issue.
Thanks Husker red
Thanks Husker red
