Engine/Transmission (1998.5 - 2002) 01 fuel and boost problems
Engine/Transmission (1994 - 1998) Is this normal or not?
i have a 01 2500 6spd ive had the truck for 8 months when i got the truck I installed a set of gauges and my fuel pres. was 10psi @ idle and 0 @WOT
so I then installed a FASS system and a full Banks kit with turbo exhaust and box with the FASS system. when i first installed the system I had 15-17 psi @ idle and 11-12 PSI @ WOT with 40lbs of boost but recently the truck has been acting wierd i have a steady fuel pres 17-19 PSI and im only able to reach 31PSI of boost as where before i could reach 40PSI and the truck use to smoke when i was on the pedal but not any more the fuel pres. never changes and it seems short on power from before . maybe some one may know what kinda problem im having i aslo just had my MAP sensor replaced.
