2nd Gen Non-Engine/Transmission 01 lost directionals but hazzards still work
2nd Gen Non-Engine/Transmission Best balljoints?
Any ideas... My 2001s directionals intermitantly stopped working and now DON"T work yet my hazzards (4 ways) still work. :{
Also I'm looking for a photo of a 2001 tailgate. I putting the new "dodge" and "4x4" stickers on.
Thanks
Good possibilty that the multi-function switch is messed up. Have you tried turning on one of the signals while messing with the hazzard button. A bad contact at the hazzard can mess up the signals-Nicholas
Check to see if the flasher is in tight. Sometimes the HD ones will vibrate a little loose. Or even fall out over time.
I also would check the flasher. The directionals and the hazards use different/seperate flashers. If a new flasher (or just swap them with each other I think they are the same unit) doesnt work then I would tear into the multifunction switch as suggested above.
Back when I worked as a mechanic for Dodge, the multi-function switches were prone to go out quite often. I bet you ten to one that that is the problem with both blinker lights are out.
The OP's 2001 (as well as yours) uses a single electronic flasher. As suggested in an earlier post, there is no HD unit.
The information in the linked thread applies model year 2001: https://www.turbodieselregister.com/forums/2nd-generation-ram-forum-no-engine-transmission-discussions/164431-turn-signals-hazards-brake-lights-n0-worky.html
The combination flasher on my 2000 Ram failed with the same symptons as the OP mentions. The Trico EP27 is a good place to start if you're planning to throw parts at the problem without isolating it to the multi-function switch vs. the combination flasher.
If you isolate it to the multi-function switch, be sure to check the price at Napa. I got mine for only $78.
Hmmm. Only $78?
<TABLE cellSpacing=0 cellPadding=3 width="100%" border=0><TBODY><TR><TD class=titletext align=middle colSpan=4>Mechanical Catalog </TD></TR><TR><TD class=tabletext style="BORDER-BOTTOM: #000000 1px solid">Item Number</TD><TD class=tabletext style="BORDER-BOTTOM: #000000 1px solid" align=right>MSRP</TD><TD class=tabletext style="BORDER-BOTTOM: #000000 1px solid" align=right>Core Price</TD><TD class=tabletext style="BORDER-BOTTOM: #000000 1px solid" align=right>Price</TD></TR><TR><TD class=tabletext vAlign=top>04728424 </TD><TD class=tabletext vAlign=top align=right>$63. 00</TD><TD class=tabletext vAlign=top align=right>$0. 00</TD><TD class=tabletext vAlign=top align=right>$47. 25</TD></TR><TR><TD class=tabletext colSpan=3>Electrical - Chassis electrical - Switches - Turn signal & hazard switch
TURN SIGNAL and HAZARD SWITCH, All Models, Club Cab, Quad Cab 2001 - 2002
</TD></TR><TR><TD class=tabletext style="BORDER-BOTTOM: #000000 1px solid" align=middle colSpan=4>Add to Cart Contact Us </TD></TR><TR><TD class=titletext align=middle colSpan=4>OEM Catalog </TD></TR><TR><TD class=tabletext style="BORDER-BOTTOM: #000000 1px solid">Item Number</TD><TD class=tabletext style="BORDER-BOTTOM: #000000 1px solid" align=right>MSRP</TD><TD class=tabletext style="BORDER-BOTTOM: #000000 1px solid" align=right>Core Price</TD><TD class=tabletext style="BORDER-BOTTOM: #000000 1px solid" align=right>Price</TD></TR><TR><TD class=tabletext vAlign=top>04728424</TD><TD class=tabletext vAlign=top align=right>$63. 00</TD><TD class=tabletext vAlign=top align=right>$0. 00</TD><TD class=tabletext vAlign=top align=right>$47. 25</TD></TR><TR><TD class=tabletext colSpan=3>
Electrical Chassis electrical Switches Turn signal & hazard
</TD></TR><TR><TD class=tabletext style="BORDER-BOTTOM: #000000 1px solid" align=middle colSpan=4>Add to Cart Contact Us </TD></TR></TBODY></TABLE>
Thomas,
Around here that is exceptional! I'll be sending you my orders from now on so that you can pick them up at your super dealer. :D
Hi David,
I'm pretty sure you can click one of the links in that post and find your way to the same dealer - and cut out the middle man (me).
Take care.
Why would I want to cut out my middle man? Actually Thomas, I've booked marked your site both at home and at work--thanks for the site. I need some new front wheel trims.
