The oil pressure sending unit in my '01 has failed again, this is the 2nd time since new. The first time it failed, I went to Cummins and bought a replacement for less than $80 and installed it... . no muss, no fuss everything was fine. This time it is a different story! Cummins no longer supplies the oem unit and says it is only available from Dodge. OK, here is the rub: Dodge only offers a replacement unit with a 1-pin electrical connector (the oem unit was a 3-pin). The oem unit actually measured the pressure, the new 1-pin unit is just an idiot light type unit, it only registers pressure or no pressure. It effectively turns the dash gage into a meaninless gage. Now here is the REAL steamer... . the new 1-pin unit requires a computer reflash in order to work and Dodge wants $150 to reflash my computer... . this because THEY redesigned the part and the oem part is no longer available!!! I can understand that I should have to pay for the new unit because the truck is out of warranty, but I do NOT think I should have to pay for a computer reflash because THEY changed the design of the unit.
I have had all my local parts store guys looking for an original 3-pin unit for me and no one can find one anywhere. Currently, I am driving with the faulty oem unit unplugged, so I don't get the constant warning chime and dash warning light..... and the oil pressure gage reads 40psi all the time... . I know it is not correct and I know I have oil pressure, but I would like to find a source for the oem 3-pin unit and install a new one.
Any ideas from the group?
