Selling my truck because of job switch, just won't be able to justify having it around and not driving it.
2002 2500 QC/SB 160K miles
- Auto with HD cooler and supplementary filter system installed by previous owner. Also has Mag-Hytek DD pan.
- 3. 54 rear, averages 20-21 mpg on non-blended fuel.
- 4WD (with CAD) I've had a problem with not getting 4WD to work in high range. I've replaced the vacuum switch on top of the transfer case and tested the lines for leaks - found none. Also tested CAD for free movement, which there is. I was going to throw on a cable system for the CAD and just haven't got around to it, don't use 4WD very much at all, and if I did need it I just used low range.
- Black leather in great shape for its age, no cracks or rips. Dash mat due to cracks in the dash. I put all new carpet in and some sound deadener last year due to a leak in the third brake light assembly. Also have a Kenwood head unit with remote and hook-ups for MP3 and USB.
- Tires and wheels have less than 3K miles on them. I was surprised they are not very loud for the aggressive pattern.
- Black bedliner and gray/green sprayed around the rockers and over the wheel wells. I also built a rear bumper out of mild steel that is sprayed the same as the rockers. Soft top tonneau cover and a behind-the-wheel well tool box with drawers from TSC will stay on the truck.
- Engine is stock (that I know of) with the exception of a K&N cone filter and housing and Edge Juice with Attitude. Straight exhaust with 5" slash cut tip with rolled edges. Doesn't use any oil and holds a minimum of 6 psi FP on wide open throttle with box set on 5. 15 psi FP at idle. I've run Fleetguard filters and Valvoline Premium Blue oil, even taken a couple of oil samples and everything is in spec.
- Completely rebuilt the front-end last fall, switching to T-style steering including new sway bar end links and mounts, new hubs, and new rotors and pads all the way around. Also has steering stabilizer bar.
Questions or more pics, you can email me at -- email address removed -- or txt to 260-330-3480. Asking $15,500 obo.
Thanks,
Eric
Thanks,
Eric
