Archived '02 3500 2WD Front Wheel Bearing
Archived Transmission Help
Archived VP44 dying...need good local repair shop
Put rear brakes on the '02. Went to do the fronts and find the Rt front wheel bearing LOOSE! Dang LOOSE!
Can it be tightened? Stamped on the flange of the nut is; "DO NOT REMOVE". Well shoot, I don't Intend on removing it. I just don't want it to remove itself.
Thanks in advance.
209 612 1370
Stranger,
I replaced my right front a few months ago. Used a 3/4" breaker bar and four foot extension pipe. A 3/4" OR 1" impact might work. The hub had to be beat off as the inner bearing was being held on by a ridge that had formed on the spindle. After fooling with a file on the ridge for a while I finally found some crocus cloth that easily removed the ridge. Make sure and get a new big nut as it is a self-locking plastic type.
Godspeed,
Trent
