Well I got it done today. I put a 02 disk brake rear end, master cylinder and all the hydraulic assist parts in my 96 1 ton dually. finally firm good brakes. every thing bolted right up even the 99 power steering pump. Same as the 96 but has all the plumbing for the hyd assist. All went well with only a couple of mods needed. e brake cable needed to be shortened and needed to make a couple of brake lines from the proportioning valve to the master cylinder. Just FYI there is a considerable difference between the sizes of the Master cyl pistons, I knew there would be due to the 4 wheel disk brakes but just surprized- about an 1/8 inch!
Also put on a ATS manifold, PDR HX 35, 16 exhaust housing and 3000 GSK WOW what a diff from the # 12 plate I had.
