I have a 2002 24V High Output Cummins. I have an Edge Comp (Drag Version) with tapped Injection Pump. I just currently had 2 codes a PO253 and P01693 set with the check engine light on. So of course I removed the Comp and the engine light went out. After scanning the computer the P1693 was a code set in JTEC Module and P0253 was Injection pump control Open Circuit I took it to the dealer and they told me they were bogus codes and only happened once. So they erased them and told me all is well. Could this be a problem with the metering valve in the injection pump or a possible wiring problem with my Edge Comp???
