Without the block heater plugged in, outside temp around 30 to 40 degrees, the longest the wait to start engine light is on, is 15 seconds. The volt meter will cycle as the heater cycles, untill enough heat is present for it not to. With the engine warm, either from running it, or the outside temp is 70 as first mentioned, the wait to start light should only be on a few seconds. Maybe 3 to 8 seconds.
