I have an 2002 Ram 2500 4x4 24V HO NV5600 all stock with 103,000 miles which has developed a problem. When you accelerate hard and start building boost it will cut-out (loose power) and smokes and backfires anywhere from 2300 to 3000 rpm depending on the load or how hard that you accelerate. It runs just fine at any rpm if you do not accelerate hard. I have searched the TDR archives and have found information that has helped along the way but I am out of things to check or try. The following is a list of what has been done to diagnose and fix the problem with no avail.
1. Pulled codes. None.
2. Checked fuel pressure at injector pump and it was 10psi at idle and 0 to 3 psi under load. Removed old lift pump from tank and installed new FASS 95gph pump by tank and new fuel filter on engine. Fuel pressure is now 16 psi at idle and 12psi under load. Still runs exactly the same.
3. Replaced the VP44 injector pump and the fuel overflow valve. Old pump was sent back and torn down by local pump shop and metal particles in fuel had damaged and scored the old injector pump. Fuel filter housing and fuel line remove and cleaned out and installed with new fuel filter. Still runs exactly the same.
4. Swapped out the ECM from an 01 HO and calibrated the APPS. Still runs exactly the same.
5. Swapped out the PCM from an 01 HO. Still runs exactly the same.
6. Blocked wastegate closed on turbo. Still runs exactly the same.
7. Removed front gear housing cover and injector pump gear. Inspected key, keyway, dowel pin, gear housing, and pump gear for cracks or nicks/burrs. Everything appeared to be okay and the key was installed properly. Still runs exactly the same.
8. Removed valve cover and inspected valve train. All valves appeared to be operating normal and opening the same as the engine is cranked over. Valve clearances were verified to be in spec. Removed the injectors and had them tested by a local pump shop. Three of them were worn worse than the rest. They were scored and blackened on the inside of the tips. An internal valve must have been leaking to let compression back up inside the tips. The pump shop said that the old injectors were the wrong injectors and they were standard output injectors and not HO injectors. Checked engine compression and it was in the upper 300psi range. Inspected connector tubes and found to be in good shape. Installed new 50hp injectors. Still runs exactly the same.
9. Monitored various sensors with computer when driving. Engine rpm matches crank sensor rpm and VP44 rpm. MAP sensor and IAT sensor seems to be within range and operating properly. Replaced MAP sensor and tested continuity of MAP sensor wire back to ECM connector. Have checked for new fault code all along the way and nothing new. Still runs exactly the same.
Has anyone experienced a similar problem or have any ideas on how to fix this problem? Any help would be appreciated.
Thanks,
Justin
Thanks,
Justin
