I have an 02 with 15,000 mi that has developed a noise within the dash. It sounds like its from inside, left side, middle. It sounds like a slight clirp/ eek almost a metallic ding da ding that is consistent with the vibration of the truck. I have pushed pulled held done everything and can not find. I have even taken off the panel below the sterring colom and felt around while driving. I have zip tied loose stuff under the dash and slammed the door on a towel at the hinges. I have checked under the hood and driven with the mirror folded in and the door open. I was told at the dealer that the shift rod for the AT transmission needed to be lubed. done still have noise. I can not make the noise while truck is parked. happens in neutral while coasting.
PLEASE help if you have had simmiliar situation
