Engine/Transmission (1998.5 - 2002) 0230 code...
2nd Gen Non-Engine/Transmission Got My RedNeckie Back
I ran out of fuel the other day in my truck. I happened to check the codes several days later and I'm showing a 0230 code, which is something relating to the fuel pump. Could this be related to running the truck empty? My fuel pressure gauge says my pressure is good. Also, if it makes any difference, my fp is relocated onto the frame.
Clear it using a scanner. The code is for an electrical failure"out of "range.
The Ecm does not see the amperage it expects at the lift pump
