Engine/Transmission (1998.5 - 2002) 02DodgeDieselCummingsnewliftpumpnotwork
Engine/Transmission (1998.5 - 2002) help needed 911
I am very new at this computer and so please be patient with me on all this. I appreciate any help that I can get on my 2002 Automatic Dodge Diesel Cummings 2002 truck. I got a new lift pump on it(2nd one I've just put on it. I hit the 30second prestart and when it starts, you can riv it up right then-But--then it will drop down to about 1800RPMS and start missing... What does anyone think the problem is here... Appreciate any help-- I was going to try and go to your chat room--but didn't know how to..... :(
LCarter said:
Dodge Diesel Cummings 2002 truck. (
Since you are new I'll let it pass this time :D It's CUMMINS, no "G"
Cycle the key 3 times and write down the codes that display on the odometer.
Turn the key to on and dont start it, turn it off-on-off-on and they should pop up.
Post them here asap.
John
First, it is a Cummins, not Cummings. Second, where are you located? Sounds like you might be sucking air into the fuel system.
Bob V
John
Like John said get the codes out of it there should be from 1 to 3 displayed be patient they roll through. replacement Lift pumps have been bad right out of the box.
Just got codes from o2 Dodge with bad lift pump
Codes that I just got after following your directions to get these are---
P1692 pecw po216 THANK YOU ALL FOR YOUR HELP
02dODGE WITH BAD LIFT PUMP--GOT CODES
SORRY GUYS--GAVE YOU ONE OF THE CODES WRONG---THR RIGHT CODES ARE-p1693 PECW PO216 YOUR HELP IS GREATLY APPRECIATED
Thanks For The Info About The Codes And My Dead Injector Pump... now---can You Tell Me Your Best Advice On Buying A Good Injector Pump And Any Other Advice... . need All The Help I Can Get. . and Do Appreciate Your Help... thank You
If your still under warrantee the dealer will replace the vp44 and also install a in tank transfer pump. If not the dealer will charge about 2500-3000 dollars to fix it. You can buy a good quality rebuilt( all replacements are rebuilt) for 1100 - 1800 dollars and expect to pay 3to 4 hrs labor if you have a independent shop to install it. There might be a TDR member close to you who would help you install it youself if needed... Good Luck!
There are many TDR members that are "supporting vendors". Do a search and decide for yourself who would be the best to buy frome. You should be able to get a rebuild vp44 well under 1400$, the dealer usually wants 2500+ for them!!
Good luck, John
I appreciate all your help with my 02Dodge Cummins... . I'm sorry I didn't get back to anyone sooner(I'm not good at all on using a computer) and am just in the learning process... Thanks again for your help
sorry I didn't reply sooner---I'm not very good on the computer and just now learning how to post and then reply... thanks for all your help on my 02dodge cummins... and no I don't have any warranties on it. . wish I did... . thanks for the help tho
Advance Diesel Technology [Doug] has the reman. pumps from Industrial Injection for $1100. + some change. I like Industrials pumps..... 2 year warranty with them & I have had no problems at all. He can usually price match competitors too. Give Doug a call @ 304-864-3399 & tell him that Jamie said to call. He is a good guy to deal with.
That being said I have Industrial Injection HR pump in my truck wire tapped the day I put it in No lope at idle and no problems at all 2 years now. :D
