03-04 Dodge transmission cooling system questions?
put rattle back in the cummins
bully dog power pup problem help
I don't own a newer dodge hence the question. Can someone fill me in on the routing of the transmission cooling system? How many coolers are used? I think there is one in the rad and also a seperate one located where? in front of the A/C condensor? Is there a seperate fan on this one? what is the path of the fluid? transmission to rad to aux cooler back to transmission?
Thanks...
Two, one Liquid Heater/cooler and one Auxiliary cooler,With a Bypass thermostat controlled system,The Stock setup is one of the Best systems on the Market.
Perfect, can I get you to email those pages and the next page (which covers install of the water to oil cooler) to me at jdnedde @ nppd (dot) com
Thanks!
