03 235 h.p. rail presure
No Box, Just tubo and injectors...?
Help Please!! Why do I hear this sound?
Does any one have the rail presure specs. for an 03 235 h. p. calif. emissions truck and are they the same as the other models?
I have 5800 at idle 10000 to 11000 pulling is this normal?
This is all measured with a snap on scan tool.
also the pressure seems to track with the fuel pressue set on the scan tool
Yes that sounds normal however if you have a pressure box the scanner will read fooled pressure rather than actual pressure.
I dont have a presure box on it now but it did have one.
others say it should max at 23000 I cant get anywhere near that number
