Archived '03 4x4 front shock lower bolt
Archived truck dead
Archived need a new 5.9
Got the top of the shock off but the nut turns when I trying to take the lower bolt out. Any idea on how to get in there to hold that nut or cut it off?? Help!
I'm guessing it's caged inside a bracket? If it's real snug in there (can't fit a wrench) and you can at least see it, jam a flat head screwdriver (preferably with a square or hex shaped shaft) between the flats of the nut and the side of the bracket - on the side that will try to pull the screwdriver in deeper as you loosen the nut.
There should be a flag on the bolt head but it sounds like it's broke off. If your replacing the shock with a new one, put some heat on the nut and hit it with an impact right away while trying to jam somethinsomething on the back side like Sticks mentioned.
Torch it off an put a real nut in there oyu can get a wrench on. If it is spinning inside the cage there is nothing to do but torch it out.
