p0483 appeared when I had a lift pump failure. cleared for awhile, and reappeared so I replaced the clutch.
Now, the intermittent operation of the clutch is gone and it seens to not work at all.
I noticed it today while towing, and when in stop and go traffic, engine and trans temp elevated. At speed (air flow) temps run normal.
I've checked the code persists, tried checking the cold start, ac switch on and off, defrost on and off and nothing seems to get the clutch to lock.
Fuse is good, still need to check for power at the connector at the lower rt of shroud.
Tomorrow I will be digging into this as I need to use this truck and warmer weather is here.
I've read many posts here and have come to the conclusion that this problem has existed for quite awhile because only occasionally have I heard the roar of the fan and temps have always crept up in traffic, and ac seems to drop off nice cold air to tepid at idle.
Looking for ideas and input on what/how to trouble shoot.
Nearest dealer is over an hour away and I'd like to avoid that for now.
The new clutch went in less than a month ago.
