'03 No back up lights
Driver side rear top shock bolt removal
Slip Yoke Eliminator
Any ideas where to start? I have nothing at the lights or the plug on back. Cannot seem to tell where to check on transmission plugs? I cannot see a switch anywhere.
Thanks for for the help
With the auto trans the back up switcth is part of the trans range sensor.It is on the left side of the trans just above the pan
According 04 wiring diagram:
Fuse 38, then WT/GY wire (into sensor), then Range Sensor, then WT/LG wire (out from sensor) and then to light bulb.
