Details here: TDR Privileges
Iam getting some vibration right after take off and as i slow down. It feels like Drive line. Any one know about removing the drive line since it has the two piece drive line. Could it be the carrier bearing. Help Thanks
U-joints probably gone dry. Do a search on here, there is probably a day of reading on this topic. As far as removing the drive shaft it is pretty straight forward. Remove from back yoke, drop carrier and remove.
If that doesn't do it then it's the carrier but by now, it's almost certainly sagging and allowing the shaft to bounce around under launch. Best thing I ever did to my truck was to install a 1 pc drive shaft. It shifts smoother than it did when new and no shutter ever.
I used the shaft from an 06 mega cab w/ G56 and had it shortened 1. 5" and balanced but any aftermarket shop could build one too.
