03 ram injectors
04.5 TST boost ?
How much is fuel pressure stock?
Is there any benefit to installing larger injectors on an 03 ho, with a pmcr,edge already on it. I had an 01 with a 40 and the usual injectors and comp box etc. . and it will walk all over my 03?? What can i do to correct this and how do i get my o3 to smoke????. It barely puffs. In fact i htink the only way it would smoke is to set it on fire. Also any body got some good pics of 03-04 duallys with stacks.
I have a set of 4 hole . 012 in mine along with 4 hole . 006 You wanna talk about smoke! PM me and I will give you the info, I have a great lead on where to get them done.
If you can't get it to smoke with the TST and EZ stacked, you are doing something wrong. As for the power issue. My truck dynoed 440 hp with nothing but the TST on 6-6 and the quadzilla fuel pressure box. That is every bit as good as most of the guys that showed up at our dyno events with comps, injectors and turbos. And I still have 3 levels to go. But to answer your question, yes. you can put injectors on top of the EZ, TST combo. But you better be looking for something to cool it down. A set up like that will most likely require twins.
I would think that your current set up now would really run good or at least smoke? The biggest drawback right now is turbo restriction and EGT's. If you can get more air in and out of your motor to burn the fuel. But if its not smoking then it sounds like your not getting the fuel you should. My TST will really smoke but with the EZ/TST on it, it smokes like a friegt train. What levels are you running? You should be pretty high up on power (I would think good enough to beat your old truck). What transmission do you have? Tests have shown that no single charger right now will gain hp with injectors on an already equiped truck with the TST. I think we need more details.
