'03 rear main leaking?
Clutch pedal vibration, SBC DD
2005 ignition on but not started-ticking noise
I have noticed over the past 5,000 mi. a small oil spot working its way down the back of my oil pan. It is now almost to the bottom. I was wondering if anybody knew if this was common and if its the rear main or pan gasket? The truck has 60,000 mi. , and with the Valvoline blue syn. 5/40 there is no stoppin' it when it finds a way out! :eek:
You might just run around the oil pan with a wrench and check to see that the bolts are all tight. Then clean the oil drip and see if it reappears. If it does then the rear main is probably the problem.
I'll be changing mine out is a couple of weeks.
Kevin
