what's the boost at when you drop on power & temps get hot?
any mods for fueling [downloader or fueling box?]
if you loose boost, you power will die off bad, and if egt is going too high, ecm is fueling to try and get the turbo to spool. in stock trim is shouldn't go past a safe fueling limit, but modified...
