Truck is disabled guys so I hope this is ok to post here. In the middle of a FASS 95 Titanium Signature Series install.
Early 04 5.9 24v. Have original lift pump on side of engine @back of fuel canister.
I need to know exactly HOW you disable/disconnect the old original fuel pump PROPERLY? These latest FASS TSS 95's do not give you the older WH1002 or 1004 wiring harness, which (from what I'm told) pluggef directly into the old lift pumps wiring plugs. The wiring harness FASS sends has you plug directly into any available 10a "ignition-hot" fuse slot.
The online instructions say NOTHING about how to properly (electronically) disable the old lift pump on side of engine. There are THREE plugs (2 wires each) plugging into my old lift pump. One on the back, and two on the front of lift pump. I believe one on front is Fleetguard fuel heater, but not sure about the one on front, or the one on the back? I need to know if I just unplug them all? Or what? Also, will doing so throw any codes or set of any dash lights?
Very surprised FASS online instructions did not cover this.
Finally, FASS has now gone to a totally reversed design with these new filters. Watwr separator is no longer first in line. Filters are indeed reversed according to Thoroughbred diesels latest video on the subject. FASS even stamped the filter location diagrams on these new filters.
SO, can anyone help me get back rolling here and properly disconnect old lift pump and fuel heater/water-in-fuel sensor so it is not trying to run all the time?
As I said, this new design has you tie directly into the fuse box, and you do not use the original lift pump wiring or plugs.
