EGT Pre/Post
Well, I am getting ready to put gages on my 04. 5 and sent Cummins an email as follows:
Powermaster
Customer Assistance Center
Cummins, Inc.
Columbus, Indiana, USA
Free QuickServe Online for Consumers at -
http://quickserve.cummins.com
Details:
This question concerns . The application is being used in a dodge
I am a member and have been reading the TDR forums for quite some time now and still have no clear answer to the question of where to locate the EGT probe.
From your information for the Jake brake, it appears you condone or even recommend post turbo. Can you provide a recommendation on which location, pre or post turbo, is the best and why? I have a 04. 5 Dodge 3500 dually with 4:10 rear, 48RE trany and tow about 11k, (5th wheel) about 50% of the time and want to protect both the engine during towing and turbo during shutdown. So, can you provide a recommendation on the best location for the EGT monitoring probe as well as the temps I should expect and/or not exceed?
Thanks for building such a fine piece of machinery. It is a real joy to own a Cummins.
This is what I received in reply a couple days later.
Summary: EGT probe location
Solution:
Thanks for your Email message.
Under full load, most Cummins engines produce exhaust temperatures in the cylinder about 1300 degF or so, on the engine dynomometer. Typically, over-the-road trucks measure EGT from two to six inches after the turbocharger in the exhaust pipe and at that point the EGT temp will be in the 700 to 900 degF range, under 'full load'.
In the Dodge Ram application, it is not likely the engine could be ran at 'full load' operation in the chassis but if it could or if overfueled, the exhaust EGT ahead of the turbocharger should not exceed the 900 to 1100 degF range. The exact temperature will vary on different applications with different pyrometers and the location of the temperature probe.
The pyrometer measures exhaust temperature and the probe is usually mounted about 2 to 6 inches from the turbo outlet (after the turbo) and in that area the exhaust temperature under 'full load' conditions should be in the 700 to 900 degF range. The pyrometer probe could be installed ahead of the turbo for maximum exhaust temperature out of the cylinders (900 to 1100 degF), however, if the probe ever fails it goes directly into the turbocharger and will likely cause a catastrophic failure of the turbocharger.
We thank you for your interest in Cummins products. Please let us know if you need assistance in locating the nearest Cummins-authorized Dealer or Distributor Service Provider. For assistance in locating a Service Provider, feel free to use Cummins North America Dealer Locator, which can be found on Cummins website:
http://www.cummins.com/service_locator/index.cfm
Please let us know if you have other questions and if away from your computer or have a time-critical request that needs more urgent attention, feel free to call us toll-free (from North America) at 1-800-DIESELS (343-7357).
Email direct: -- email address removed --
Regards,
So, the temps some of you guys are seeing far exceed those Cummins gave to me in the above email. Either they are being very conservative or some of you guys are really pushing the metallurgy to the limits or perhaps the pyro type and location really makes a huge difference. I still don't feel like I have the answer as to what temps I should not exceed. I am leaning towards post turbo since I am running stock and want to watch the shutdown temps.
George
