Ok guys i could really use some help. I just had my oil changed like 10 miles ago pulled on the freeway truck had no power would olny go 60 mph . I seen my buddys exit so i limped to his house . The oil change place change oil and checked air filter . so i thought they boke a sensor on the air filter nope . i held the odometer button and turned on the key the truck had a 6799 code not sure what this means . I must have reset it becauase now when i check there is no code .
The truck has no power fuel filter has 4000 on it and i have put 120 miles on this tank with no problems . I had an 01 and it got better mpgs than this i am getting 14 at 75 i got 17 or better with the 01 . not sure if this means anything . the truck is still under warrenty so i did not want to drive it home its about 65 miles . Ihope you can help Thanks
