The 305 engines are capable 500 HP with stock injectors and well over 600 HP with upgrades. Why not work with what you have and enhance it? If you crave really big HP, P-pump it.
True. But how many actually made 500 with stock injectors? Not many that I know of!
I know I was not able to get over 430 without an injector change.
Took alot of upgrades just to hit 600!
I have worked on this truck for over 3 years now. I have sucked up as much info as I could. Changed every part from the fuel in the tank to the tip of the injector. Still... Low numbers.
I have taken the head off, checked everything there. . Pistons and walls looked great! Head had some minor cracks around the valve seats. . But nothing major. valves sealed fine.
I have had two different twin sets. Also, two different top turbos on the current set. Still, low numbers.
I have narrowed it down to an electronic issue at this point... But still not sure what way to go.
I guess mine is just one of the ones that doesn't want to make power.
As for the P-Pump... That would be a big step backwards if you ask me. If I wanted to build a 12 valve I would have. Seems like everybody and their dog has done it.
I guess I have two choices at this point. . Keep looking for a solution to the problem the truck is having. . Or start over with another truck.
