04.5 Service Manual Source/Fluid capacities
ETR/JL injectors
Lift Pump Experience
Any suggestions on the best buy for a service manual covering a 2004. 5 3500 CTD? Also, the owner's manual neglects to reveal the capacity for the differentials, transfer case and transmission. I want to order replacement fluids, so any info would be appreciated.
AXLE
NOTE: DaimlerChrysler recommends using MoparT lubricants or lubricants of equal quality.
FRONT AXLE
² C205F - MoparT Gear Lubricant 75W-90
² 9 1/4 AA - MoparT Synthetic Gear Lubricant 75W-90
² 9 1/4 AA EL- MoparT Synthetic Gear Lubricant 75W-90
REAR AXLE
² 9 1/4 - MoparT Synthetic Gear Lubricant 75W-140
² 10 1/2 AA - MoparT Synthetic Gear Lubricant 75W-90
² 10 1/2 AA EL- MoparT Synthetic Gear Lubricant 75W-90
² 11 1/2 AA - MoparT Synthetic Gear Lubricant 75W-90
² 248RBI - MoparT Gear & Axle Lubricant SAE 90
NOTE: Trac-LokT differentials require Limited Slip Additive in the lubricant. Trac-Rite™ / Trac-Rite EL™ differentials
DO NOT require Limited Slip Additive. DESCRIPTION SPECIFICATION
8. 3L 15. 1L (18 qts. )
AUTOMATIC TRANSMISSION
Service Fill - 48RE 3. 8 L (4. 0 qts. )
Overhaul - 48RE 14-16L (29-33 pts. ) L
MANUAL TRANSMISSION
G56 5. 67 L (12 pts. )
GETRAG 238 2. 2 L (4. 2 pts. )
NV5600 4. 50 L (9. 5 pts. )
NV4500 3. 79 L (8. 0 pts. )
TREMEC T-56 2. 27 L (4. 8 pts. )
TRANSFER CASE
NV241 GENII 1. 6 L (3. 4 pts. )
NV243 1. 6 L (3. 4 pts. )
NV244 GENII 1. 6 L (3. 4 pts. )
NV271 1. 89 L (4. 0 pts. )
NV273 1. 89 L (4. 0 pts. )
FRONT AXLE ± . 03 L (1 oz)
C205F 1. 6 L (56 oz. )
9 1/4 AA 2. 2 L (76 oz. )
9 1/4 AA EL 2. 2 L (76 oz. )
REAR AXLE ± . 03 L (1 oz)
9 1/4 2. 1 L (72 oz. )***
10 1/2 AA 2. 5 L (85 oz. )
10 1/2 AA EL 2. 5 L (85 oz. )
11 1/2 AA 3. 6 L (122 oz. )
248RBI (DANA 60) 2. 8 L (46 oz. )****
**** Add 147 ml (5 oz. ) of Limited Slip Additive
*** With Trac-Lok add 118 ml (4 oz. ) of Limited Slip Additive.
** Includes 0. 9L (1. 0 qts. ) for coolant reservoir.
*Nominal refill capacities are shown. A variation may be observed from vehicle to vehicle due to manufacturing
tolerance and refill procedure.
TRANSFER CASE
Recommended lubricant for the NV241 GENII, NV271, NV243, NV244 GENII, and NV273 transfer cases is MoparT
ATF +4, Automatic Transmission Fluid.
Go here for a free download of the factory service manual. I downloaded the one for my 05 and it was over 8000 pages. It does include our CTD. It is a very large file.
