It is not the same turbo as the 03/04.
The 04. 5 unit has an electronically controlled wastegate. Also 4" exhaust elbow.
The 03/04 turbo has an 9cm compressor housing with hx35 series size compressor wheel, hx35 sized turbine wheel.
The 04. 5... 9cm turbine housing, Hx40 sized compressor wheel and 12 cm compressor housing.
I dont know the series name (HY series is what I read on here).
The diameter of the turbine blade is the same as the H1C, HX35 and Hy35.
--Justin
