Have a an 04 dodge in shop. Truck cranks and owner ws using ether to start. When reving the truck in park after you let off it would continue to climb and then come back down. Made a cap for the rail and capped off individual cylinders. Found that the truck started when i caed off #2 Installed a new injector and problem is still there just not as bad. Swapped out the pressure actuator and no change. Does not seem to have fuel in the oil. Any Ideas??
