04 Impala ?
"07 Lifted Tundra"
Chevy Electric Brake Port
Has anyone out here changed rotors on an 04 Impala? I am in need of changing mine, but dont know if there are any special tools required or anything else I should be aware of before I start or attempt it.
nothing special, if this is the first time having the rotors off you might still have the factory retaining clips on 2 studs, just cut/break them off and discard them, you will need to remove the caliper, 12mm if i remember right, and the caliper mount 13 or 15 mm then you might need to "persuade" the rotor off the hub with a hammer. they rust to the hub. pretty easy will take about half an hour
