A friend of mine has a cherry '05 Dually, automatic, 3. 73 2wd that he tows a huge 32ft 5th wheel. His truck has the "TOW" button not "TOW-HAUL" but it doesn't lock out 4th like my old 01. 5 did.
Question is, What is the way he needs to go to manually downshift from OD to third/direct for hills? He has tried pulling down the shifter under load but it won't drop. I had a built DTT in my '01. 5 and if I needed to go into second, I had to let off of the throttle to get it to go in.
Is his '05 tow button the same as the '01. 5 or does it just change the shift points???
I loaned him my Smarty jr set on 40hp with timing and soft torque to see if his EGT's would drop. I installed a Westach EGT and he was seeing 1400deg
towing!!!
