I've run into a P0088 high rail pressure code and a rough idle/die condition at startup. *I think I may have gotten a batch of dirty gas, as I limped into the station the other day while the semi was filling the station tanks. *Only got ~10gals but a day after that, this issue started. *I've pulled a sample of diesel and I'm waiting for it to settle out, as well as pulled the filter. *Filter is pretty gnarly and gunked up. *I've also pulled the FCA and attempted to clean it with some WD40 in the ports to see if that will help get it running right again after a filter change.
Question: does the FCA for the '05 5.9L rattle when you shake it? *Mine isn't rattling even after cleaning...
Not sure if I should siphon the tank, drop it, and flush it, or drain it and refill with clean diesel and a crap load of additive. * What do you guys think?
Any other things I should think of before going further?
I just put a secondary CAT filtration/separator combo on order and will definitely install that before I attempt to start the truck back up as well.
