I'm working on an '05 3500 with a fried clutch (company truck). I'm doing away with the DMF in favor of a solid flywheel (G56 trans). I have a good used aftermarket flywheel from SBC with the HD ball bearing pilot that I ran on my own truck for a while. My question is will this flywheel work on the '05 or is the solid flywheel different in this application. Also does the retrofit use the same 13" clutch as the NV5600 application. I'm just trying to find a little cheaper rout than the full SBC kit and would like to use the flywheel I have if possible. I know Valeo also has kits out for a lot less. The truck is stock so no need for a high HP clutch. Also trying to get it on the road faster with parts that I have close by. Also I see the SBC kit as well as some others include the hydraulics. Is this necessary?
Here is a picture of the OE 12 valve flywheel redrilled for 13" clutch and the SBC aftermarket 13" with HD ball bearing pilot.
