Hi guys, I just did something really stupid! I lost oil pressure on the gauge the other morning about 1 min after I started it for the first time of the day. I shut it down and restarted it and the pressure came back up. I have been having some electrical gremlins lately so I did not give it a lot of thought and I continued on. About a mile or so later it did the same thing but now I am on a little highway with no shoulder and had to continue for almost 2 miles to find a spot to stop. Before i could get there I heard a dreadful sound as it started knocking. I puled over and shut it down a quickly as I could. I checked the oil and there is nothing on the stick!
I walked to a gas station and came back with 4 quarts of oil, which brought it back up on the stick. I re started it and it quieted down and sounded normal. My next mistake was to continue on down the highway because after about 15 miles it started knocking again. I pulled over and had it towed. I plan to drop the oil pan and cut open the oil filter this week to see what kinds of metal I find. Truck is an 05' with 80K miles. I am looking for some advice. Should I do a Cummins recon short/long block, or should I take it somewhere to have my engine rebuilt. I was thinking about calling Enterprise out in Ohio or Scheids diesel. I am in eastern PA. Anyone else you guys can recommend? I am guessing this little mistake is going to cost about 5-6 grand. Am I in the ballpark? The one advantage I can see in going with say Scheids is that I could have them throw in a cam and some head studs while they have it apart. At least then I may end up with at least some benefit after this costly adventure is finally over. Any advise would be greatly appreciated. Thanks.
Kevin
Kevin
