Hello all
I was at the dodge dealer today they have a 05 ctd in the shop with a #6 piston bore scored the only thing is that this truck is stock no chip no power box nothing (NO MODS). they did not know what caused this to happen Cummins was not sure what happened . if you look at the walls of the rest of the bores it looks to me as if the fuel injection is putting to much fuel in to the motor and its washing the walls down this truck is a farm truck and farmers are use to letting there trucks idle for long periods of time! the person working on the truck said that this was about the 14 truck (all 05's )they have seen and have replaced the engine . (this scares me!!!!)
could this be the third event in the injectors doing this and if so is there some one out there that can reprogram the computer to stop the third event
the oil in my 05 turns black after 500 miles the oil in my 04 stays clean for 5000 miles plus 04 has 555 / 05 has 610
you could see the cross hatch in the block i did not get the milage but i will monday
