'05 Fuel fliter change, stock
20 year-old vs new starter waveforms for curiosity
Issues getting out of Park
Do you personally drain the canister first before you take the lid off and pull the old filter?
Watched a thouroughgood deisel vid and he waited to drain the canister after he removed the lid and filter
whatever
You absolutely have to, otherwise you flush the dirt sediment into the clean part of the bowl. Never pull that filter on a full bowl.
I drain first and take top off once fuel has stopped flowing but leave the drain open (into a bucket of course) as when the lid comes off, more always flows out.
Welp, Got that new filter replaced tonight. First time on a 2005. Pretty easy.
My '99 has a Fass Titanium fuel pump with Fass filters
I used a stiff tooth brush type brush and a air compressor to clean around the lid before I removed the lid.
There was alittle loose crap in the bottom of the bowl, I used a shop vac and sucked it out clean
I started cleaning my battery terminals. Completely took apart and off the battery and wire brushed every thing, completely cleaned the crud and red crap previous mechanic sprayed on the terminals.
Ill be redoing the Bat Terminals again with Military Spec terminals and Battery cable end lug/ring soon
I installed a new water pump a few days ago. No more dripping leaks. Old pump was really shot , fricken wobbly loose bearing when I got it off. It was dripping a few drops when parked when I first bought the truck last summer
The red crap helps with corrosion if you're not running an AGM battery. If using a lead acid battery, the off gassing causes the corrosion. When you do the cable to lugs, if you don't have heat shrink with the glue in it, just use a heat gun and hot melt glue stick to spread around connection and before it cools completely, slide up heat shirk and then seal up tight! Have use this method on an LED in a water feature in the yard with great success from the elements. Glad you're taken care of the rig! Enjoy the seat time!
