05 gauge install?
2006 Keys
limited slip
I'm going to be installing gauges myself on my 05. Could somebody tell me which wire to tap for the dimmer controls for the gauges. I have an 05 shop manual and here is what it lists for the pin-outs. Not sure if it's 3 or 6, but I'm thinking that it's either one.
SWITCH-HEADLAMP - 8 WAY
CAV CIRCUIT FUNCTION
1 - -
2 - -
3 E19 20OR/BR HEADLAMP SWITCH DIMMER SIGNAL
4 Z407 20BK/OR GROUND
5 L89 20WT/YL (FOG LAMPS EXCEPT
SRT)
FOG LAMP RELAY OUTPUT
5 L89 18WT/YL (FOG LAMPS SRT) FOG LAMP RELAY OUTPUT
6 E2 20OR/BR PANEL LAMPS DIMMER SIGNAL
7 L115 20WT/YL HEADLAMP SWITCH RETURN
8 L116 20WT/LG HEADLAMP SWITCH SIGNAL
On my 05 there was 2 orange wires with a brown tracer, one went to the dome light the other was the dimmer switch. Use a test light to find out which one is which, and for power I tapped into a (if memory serves me right) a pink wire leading from the cigerette lighter.
I used the dimmer for the a/c controls since they are right there. Used the meter to verify the right one after viewing the wiring diagram.
Big P, I can't remember which pin # it is but if you're facing the dash it's on the bottom row, closest to the door.
Karl
