05 headlight adjustment - Up- Down only
Windshield wipers
Where best to invest $5k to improve truck performance?
Looky like only Up - Down ONLY,,,,, No lefty- righty head light adjustment on my 05
Oh My ... You Concur that ?
:D:eek::cool:
Yep that's normal for them, and it's actually okay for the basic US symmetrical light pattern. The TYCs have both adjusters.
I got the one new right side depo installed on my 05.
It had a new one on the driver side from the dealer when I bought the truck last year.
Right side wasnt super bad but you could tell it was older/original headlight
Got the lights adjusted. had to lower the New pass side, and I raised the driver side a little , It seemed too low when I got the truck
Now I got 2 new sport headlights to install in my '99, they are TYC. Waiting for my sport conversion relay wire loom to arrive. I might get 2 9007 Sylvania Xtravision bulbs for those. One step up from the Basic bulbs. I dont need bright white bulbs that have short life span
:D:eek:
My old bulb in the housing I replaced was a Philips 9007 LL (long life) Made in Germany
Are Hella and Philips the same bulbs?
Think Ill pull the driver-side and see what bulb is in there. Its a newer depo so I thought it might be the same. But its a very tiny bit brighter and wider than the new pass side Sylvania bulb, when I block off the light on each side to compare
No one has every mentioned the LL (longlife) bulb
