05 Juice w/att. question
05 Twins ???
Jacobs Exhaust Brake
Ok, my question is, I thought that I could program it so I could over ride the safety. I know that when I push the enter button twice it is supposed to shut off the safety. But when I do that (and set the time) and try to do a holeshot or spin the wheels you can feel the truck starts to pull hard then actually defuel. It will pull real hard then let up and do that a couple of times while it is accellerating. Any thoughts on this subject? Thanks agian for your help.
Snoxracer
When you double press the enter button real fast, the timer come on, adjust the timer up to 30 minutes and then push enter again. When it goes back to the standard screen, the power level number should be blinking off and on, is it doing that? If it isn't, you probably have a defective box. If it is, and you still feel it de-fuel, then I would say that the box is defective also. Call Edge and they will send you another one.
