Archived 05 lost power
Archived Headlights turn on themselves, flashing while parked!
Archived Lurches and Stalls When Put Into Drive
NFranco
I have an 05 6spd running fine then all of a sudden lost A/C, then lost power in
6th gear. I can run 1-4th and travel 60mph but thats it. Got the following
trouble codes P0299, P0647, and P1246. What are the codes, and what should I look for, appreciate any help.
299 is a "Supercharger underboost"
647 is a "A/C clutch relay circuit HI"
1246 I'm working on... its Chrysler specific...
Your truck has put itself in "limp" mode. Do you have any boxes on it? Limp mode will clear itself out if the conditions are fixed and you start/stop the engine 3 times. You have to actually drive it between key cycles though. Either that or you have to clear it with an ODB code reader.
Result
I limped the truck to the dealer... it turned out to be a shorted out #3 fuel injector, $1000. 00 parts and labor ouch... ... .
