Pardon my rambling on this. I am still trying to figure out the logic driving the torque converter clutch in my '05 automatic, especially in tow/haul mode. I want to add an exhaust brake such as Pacbrake but am confused about when the TC is/is not locked up and if I need an additional transmission controller.
When going down a long hill with no throttle applied the transmission will go into a retard mode. Is this simply a TC lockup or is it down shifting? In the Tow/haul mode does the TC stay locked up when you back off the throttle?
Is there a place where I can monitor the lockup clutch signal? Given a connector and wire color I can make a monitor that will insure I have a lock up before applying the Ebrake.
Any information will be greatly appreciated.
Thanks much in advance.
