05 Toe-in
Fuel gauge for nephew.
Lift kits and wheels
. 15 degrees max and . 05 degrees min is the range that is within specification.
There are things to consider like how hard you corner, if your steering is stock what came on the truck or if it has been up graded to the late 08+ style and if you change loads often or load the receiver often or have aftermarket wheels with less offset than oem as those conditions can make a difference.
Best place to start is to find out what it is now and evaluate the tire wear and then adjust as needed while staying in the "range" given.
