Those of you who have changed the cartridge in your Turbo... ... how did you separate the exhaust housing from the cartridge once you pulled the clamp loose????
And on the Fresh Air Side, do you need to remove the snap ring and what's behind it need to be pulled off to get the fresh air side of the turbo apart... .
Thanks for the info...
So after I wrote the above... . I went back out and looked at it more closely and used a sharp chisel to separate the exhaust side from the cartridge... . tap, tap, around the two housing and it came apart... . and cleaned up with a wire brush... .
So I'm no happy...
So I'm no happy...
