06/03 Dually Fender Differences?
NV5600 Oil change?
Taller (NOT wider!) 17" tires?
The 03 dually apparently has larger rear fenders then others as Torklift had to make a special bracket to move the tie down anchor point farther back on some campers so that the tie down would clear the fenders. I know there have been some “minor” changes to the body since 03. Does the 06 use the same size fenders? For a point of reference, here’s what has me pondering this. http://campertiedowns.com/dodge_duallys.htm
Thanks,
Ken
Ken,
Lance makes a replacement rear tiedown bracket that replaces the original rear brackets on Lance campers designed for use with the third generation Dodge DRW trucks. My dealer gave me a set for free.
I use the Happijac frame mount tiedown system and the Lance bracket moves the rear tiedown further away from the DRW fender. Using the original rear tiedown bracket, the tiedown didn't touch the fender, but it was close.
Bill
Hi Bill,
Thanks for the info. I found out about those brackets from Lance yesterday, after I posted this question. So looks like I will get them. Glad to hear they help.
Ken
