I've got a DTT fully built transmission with all the billet guts and a triple disc torque converter.Ok my truck started acting like the torque converter clutch solenoid was going out so drop the pan replace the solenoid and I also replaced the governor pressure sensor and solenoid at the same time. Changed the in pan filter and changed my remote filteR as well. put fresh fluid in and when I started the truck up after everything was put back together it's giving me code p0868. and for some reason it feels like it's up into the break harder than it should be. almost like you're giving it partial throttle when at idle. Thanks in advance for any and all help
