I had the A/C compressor seize on me on a road trip the other day, which also snapped the serpentine belt. Since I was in the middle of nowhere and I needed to get home (150 miles) that night, I ended up getting a replacement compressor and changing it out in a Mcdonald's parking lot. I'm not an A/C guy, but sometimes situations make us do things we don't know enough about.
The compressor came with 3oz of oil in it, which was enough to get home on, with a discharged system. Then I had no time to vacuum the system down before I had to make another road trip, so I put a couple small cans of oil in it and a couple cans of refrigerant, just so I could get on the road again. Now I have a couple days home to do a better repair, but I'm not exactly sure what needs to be done. I'm told that there is a screen somewhere that I should've cleaned and some type of dryer that should be replaced? Can anyone help me find these parts on the truck? Once these things are corrected and the system is drained again, I should be able to vacuum it out and recharge it correctly, right?
Does it hurt the vehicle to drive it the way it is?...with oil and refrigerant in the system? I'm not trying to use the AC, although when you first turn it on, it blows cold, but within 15 seconds it starts to warm up.
Thanks in advance.
Thanks in advance.
