06 AC compressor fix. A coil kit is available
No cab heat
Anyone know when the Diehard Platinums are on sale?
I ran across this post on the Cummins forum about how to repair the coil on 06 and above compressor on the diesel without having to replace the whole compressor.
Here is the post. Its long but good. Towards the end is an add on about the part from Sun Air.
http://www.cumminsforum.com/forum/3...diy-fix-ac-compressor-clutches-going-bad.html
Here is the parts info from Sun Air
http://www.sunairusa.com/news/CC-401EBulletin.pdf
http://www.sunairusa.com/news/HS18Clutch.pdf
http://www.sunairusa.com/news.html
Also worth noting. Autozone has a clutch tool rental for the clutch removal for $25. If you return it they refund the full amount. If you want to keep it, the rental is its cost.
